Big_Al
4 years agoExternal Memory Interface IP on Agilex.
Hi, I am new to Quartus Prime Pro. I have instantiated a external memory interface in a Qsys design for an Agilex part. I have also generated the example design and simulated it. Looking through the ...
sstrell
4 years agoHave you gone through the user guide? There's a lot to setting up an EMIF:
- Big_Al4 years ago
Yes, I have been through all the documentation and videos. The user guide seems to concentrate mainly on the phy side, which is all very interesting but what I really want to know more about from a user point of view is the Avalon interface. I could try to work it out from my own test bench, but I can't help but think it is probably documented somewhere, which would save me a lot of time.- sstrell4 years ago
What aspect of Avalon? Avalon in general or like the register map of the EMIF IP? You can learn more about Avalon itself in the spec:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
- Big_Al4 years ago
I have read the Avalon specs and have used axi before. My specific issue is as I mentioned above on the 5 Nov. The Avalon interface on the emif is 576 bits wide. There are no byte enables and only 29 address bits. So if I want to write to a Specific byte, how can I do this? I would have thought this might be explained somewhere along with other questions like details on when a burst mode starts. Is it after the last bytes of the last 576 byte word is written?
