3one5's avatar
3one5
4 months ago
Using Reset Release IP (Agilex, Stratix) without IP catalog via simple instantiation is ok?
Anything against using the reset release IP without going the IP catalog -> Platform Designer way bey simply:
-- library clause to make the altera library containing
-- the internal implementation of reset release IP visible
library altera_s10_user_rst_clkgate_1949;
entity...
end entity;
architecture ...
  -- declaring the component for VHDL fitting the internal
  -- reset release IP (name and port naming have to fit
  -- for VHDL default binding)
  component altera_s10_user_rst_clkgate is
    port (
      ninit_done : out std_logic -- ninit_done
  end component altera_s10_user_rst_clkgate;
  signal nInitDone : std_ulogic;
begin
  -- instantiation of the reset release IP
  TheResetRelease : component altera_s10_user_rst_clkgate
    port map (
      ninit_done => nInitDone  -- ninit_done.reset);
  -- combine the asynchronous reset signal combinatorially with the
  -- nInitDone signal in the further code
end architecture Rtl;
This would speed up things and has improved readability also.
If it is not ok, please give concrete reasons speaking against this approach.
1 Reply
  • ShengN_altera's avatar
    ShengN_altera
    If I'm not mistaken, you mean straight put that piece of code in a .vhdl file right?
    That should be no problem.
