anonimcs's avatar
anonimcs
2 years ago
Constraint clocks of SPI interfa
Hi all,
I have a design where I generate an SPI clock and send some data over the slave. The slave is an ADC with its own setup/hold time constraints. In these constraints, the slave data input SDI has constraints with respect to the SCLK, but I'm not sure how to properly constraint that. What I did so far is that I constrainted the SCLK on its own as if it's a data output of the FPGA and then constraint the MOSI with referencing the SCLK. The syntax I used in the sdc file is added below.
# main clock of the FPGA
create_clock -name {clk} -period 100MHz [get_ports {clk}]
# Specify generated clock from PLL (PLL output is 100MHz)
# set_instance_assignment -name corepll_inst|altpll_component|auto_generated|pll1 -to pll_inst
# create_generated_clock -name {pll_clk} -source [get_pins pll_inst|clk[0]] -divide_by 1
# constraints for SCLK and MOSI
set_output_delay -clock {corepll_inst|altpll_component|auto_generated|pll1|clk[0]} -max  3 [get_ports {SCLK1}]
set_output_delay -clock {corepll_inst|altpll_component|auto_generated|pll1|clk[0]} -min -2 [get_ports {SCLK1}]
set_output_delay -clock {corepll_inst|altpll_component|auto_generated|pll1|clk[0]} -reference_pin SCLK1 -max  5  [get_ports {MOSI1}]
set_output_delay -clock {corepll_inst|altpll_component|auto_generated|pll1|clk[0]} -reference_pin SCLK1 -min -5  [get_ports {MOSI1}]
What I observe in the Timing Analyzer is that the setup and hold times are not the only things when checking the timing analyzer. For the example that you can see on the snippet attached, I would expect that the data required for the setup time of SCLK1 would be only 3 ns far from the latch clock's posedge, where the cursor is. I'm almost sure that what I want to achieve does not match with the constraints I used, therefore I'd like to ask what I'm doing wrong or missing.
Any help is much appreciated,
Cheers
  • anonimcs's avatar
    anonimcs
    2 years ago
    Adding the pins of the Quad SPI IP did not work, but generating another clock like this and constraining the other QSPI ports wrt. this clock seems to work somehow
    create_generated_clock -name {qclk_vclk} -source [get_pins {corepll_inst|altpll_component|auto_generated|pll1|clk[0]}] [get_ports {QSPI_CLK}]
    • TingJiangT_Intel's avatar
      TingJiangT_Intel
      I upload the user guide here
      • anonimcs's avatar
        anonimcs
        Hi @TingJiangT_Intel ,
        I don't get how I can do what I've described in this entry with virtual clocks then. Because I wanted to use the sclk1 outputs to check the timing of some certain ports. What would be the right approach here ?
  • I'm not really quiet understand what you mean by 'use the sclk1 outputs to check the timing of some certain ports'. Based on the current SDC file the main problem is the clocks you created are ignored.
    If you want to create a virtual clock you can use the 'create_clock' constraint.
    • anonimcs's avatar
      anonimcs
      What I meant by that is this: I want the SCLK1 clock output to be used for checking the setup/hold time violations of MOSI1 and MISO1 ports for example. The setup/hold time requirements are given by the manufacturer of the external chip. But at the same time, I want to check SCLK1, MISO1 and MOSI1 with respect to the pll clock to verify that the timing is right for the FPGA itself as well as the external device.
  • Currently, you output/input delay​ constraints are invalid due to the previous problem we discussed which caused these paths unconstraint, and the software won't analyze these paths.
    You need to first fix the issue of ignored constraints.
    Please apply 'set_instance_assignment -name corepll_inst|altpll_component|auto_generated|pll1 -to pll_inst' to the qsf file instead of sdc file. Or you can directly use 'corepll_inst|altpll_component|auto_generated|pll1' instead of pll_inst.
    And don't use get_fanin to get the source clock, please try to use wire_pll1_clk[0]~clkctrl as the source clock of qclk.
    I can't apply changes to your sdc file, so please try the modification from your side.
    Hope this can help.
    • anonimcs's avatar
      anonimcs
      Should I use `get_nets` then to use that wire ?
    • anonimcs's avatar
      anonimcs
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
