15 years ago
SDRAM problem in SOPC builder
I get this warning message in SOPC builder saying:
"Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function across 28 bit boundary is not supported by GCC and will result in linker errors"
when i try to add a SDRAM to my NIOS2 system which already has 128KB on-chip memory, and 2MB SRAM.
But the warning message dissapears after i disconnect the instruction master bus from NIOS2 to the SDRAM. what is the significant of having instruction master bus connected to SDRAM? if i don't connect it, what disadvantage/advantage will i get? the obvious advantage is that, i can generate HDL, since there is no more warning message after disconnecting.
i also found out that, if i define the base memory of SDRAM to be 0x00000000, and SRAM to be 0x0a800000, and lock them both without disconnecting any buses, the warning message will not appear... im confussed..
Someone please answer my question.. i really appreaciate it. Thank you.
regards,
Michael
PS: I'm not a real ALTERA teacher... the forum tries to make fun of me after i asked too much questions here.
