15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
15 years agoMichel,
the size of your SDRAM should not be a problem. I doubled the SDRAM in my SOPC from 64Mx32 to 128Mx32 and I didn't receiver any SOPC builder errors (see attached JPGs). Did you typed in a correct memory profile and timing parameters for the SDRAM in SOPC builder? You could refer the DE2-115 System Builder which is able to generate a Quartus project. In your code the memory allocation for SDRAM is not complete. You should use:buffer = ( alt_u32* )malloc( SDRAM_MAX_WORDS * sizeof(alt_u32)) Jens
