otto-Q's avatar
otto-Q
1 month ago
Nios V/g load-writeback hazard
Summary
On a NiosV/g core, a long-latency load from an on-chip memory immediately followed by a short-latency load from the core's own TCM returns the TCM load's data in both destination registers. The first load's writeback is lost.
lw a0, 0(t0) # t0 -> On-chip memory
lw a1, 0(t1) # t1 -> DTCM (core-local) # a0 and a1 both end up holding the DTCM value
Inserting a single instruction between the two loads is enough to avoid it. Two on-chip memory loads back to back are fine, and so is the reverse order (TCM load first, then the on-chip memory load).
Minimal reproducer
Assembly:
_start:
 lui t0, 0x40         # t0 = 0x00040000 on-chip memory ("input memory")
 lui t1, 0x10         # t1 = 0x00010000 DTCM (core-local)
 lui t2, 0xe0         # t2 = 0x000e0000 2nd on-chip memory ("output memory")
 li a2, 0x47414c47 # a value distinct from the DTCM sentinel
 sw a2, 0(t0)         # ...store it into input_mem
 nop                  # let the store retire. The hazard is about two
 nop                  # adjacent *loads*; keep everything else well
 nop                  # clear of the pair below so the test stays
 nop                  # unambiguous.
 lw a0, 0(t0)         # long-latency load: on-chip memory (input memory)
 lw a1, 0(t1)         # short-latency load: DTCM, immediately after
  sw a0, 0(t2)          # output_memory[0] = result of the AXI load
sw a1, 4(t2)          # output_memory[1] = result of the DTCM load
spin:
j spin
System details
NiosV/g data_manager (AXI master) is directly connected to on-chip memories and pipeline stages are limited to 3 in Platform Designer.
  • otto-Q's avatar
    otto-Q
    Thanks for the answers! I/we will test with Quartus 26.1 and report back to you after that
    • tehjingy_Altera's avatar
      tehjingy_Altera
      Hi otto-Q
      Did you managed to try out on the Quartus 26.1?
      Are you still facing the same issue?
      • otto-Q's avatar
        otto-Q
        Sorry, not yet, this is delayed by some days due to internal reasons
  • otto-Q's avatar
    otto-Q
    This was found in Quartus 25.3 and has not been tested in newer versions
  • AvinashTh_Altera's avatar
    AvinashTh_Altera
    Can you please try Quartus 26.1 pro release and let me know if this issue exists? thanks
  • Hi otto-Q,
    Thanks for the clear write-up and for confirming you saw this on Quartus 25.3. This looks like a known Nios V/g quirk with back-to-back loads when a longer-latency AXI/data_manager access is followed right away by a DTCM load. That one was fixed in Quartus Prime Pro 26.1.
    If you get a chance, it’d be great if you could try your test again on 26.1 Pro with the same Platform Designer setup, and let us know if a0 and a1 come back with the right values. No rush — whenever it’s convenient. And if it still looks off on 26.1, just tell us and we’ll dig into it with you.In the meantime, that one-instruction gap (or DTCM-first order) you already found is a solid workaround on 25.3.
