Mailbox Client HAL API: Erroneous behavior in flash erase boundary checks (Agilex 3 / Nios V)
I am currently working on an Agilex 3 platform using the Nios V in Quartus Prime Pro 25.3. I discovered unexpected behavior in the Mailbox Client HAL API when trying to erase 32K blocks of flash.
In the file intel_mailbox_client_flash.c in function mailbox_client_flash_erase_block:
The function receives a dynamic block_size as an argument but ignores it during the boundary check, relying instead on the global dev_info->region_info.block_size.
Because it checks against the maximum hardware block_size (i.e., 64K) instead of the actual block_size parameter passed to the function, it mistakenly blocks legitimate erase commands at the final sectors of the region. Below is the code snippet:
int mailbox_client_flash_erase_block(intel_mailbox_client* fd, int block_offset, int block_size)
if(block_offset < 0 ||
block_offset > dev_info->region_info.region_size - dev_info->region_info.block_size ||
(block_offset & (SZ_4K - 1)) != 0)
return -EINVAL;
I suggest changing the boundary check to use the local block_size parameter that was explicitly passed to the function:
block_offset > dev_info->region_info.region_size - block_size ||
return -EINVAL;
A similar logic flaw exists in the caller function mailbox_client_flash_erase.
The input validation check uses the static hardware block size (dev_info->region_info.block_size) instead of taking the requested length into account.
I suppose this check should prevent out-of-bounds erases in the first place, so checking if there is one 64K block left in the flash is actually pointless.
int mailbox_client_flash_erase(intel_mailbox_client* fd, int offset, int length)
if(offset < 0 || offset > dev_info->region_info.region_size - dev_info->region_info.block_size)
return -EINVAL;
}I suggest using:
if(offset < 0 || offset > dev_info->region_info.region_size - length)
return -EINVAL;
Any feedback on this behavior would be appreciated.
Thanks!
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
