glenenglish's avatar
glenenglish
1 month ago
NIOS-V-64bit - why no double precision FPU ?
We need the 64 bit NIOS for several projects
and must have a double precision FPU option.
But the documentation so far lists only a single precision FPU
Is this correct ? a 64 bit processor not having a (64 bit) double precision native FPU option seems unbeleiveable .
It is about as strange as say, not having an 64 bit ALU.
Altera- please explain ?   page 3 :
https://docs.altera.com/v/u/docs/759484/nios-v-processors-for-agilextm-5-fpgas-e-series-technology-brief
Or please add this to the basic feature provision ?
With thanks
Glen.
(Experienced Xilinx user consideriing migrating-defecting to  Altera )
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
  • glenenglish's avatar
    glenenglish
    Hi Avinash
    Thank you very much for the advice and correction.  This is good news.
    Do you have a guessimate timeframe for the beta availability of this core at this time ?
    background : While the A55 options for A3C  (and A5E) meet our higher performance requirements, we're looking at how we satisfy our low -mid range SoC equivalents at a price target. Zynq7000 series is very cost competitive, and Altera does not have cost competitive SoC option for that (in Agilex fabric) , therefore we are considering an option of the RISC-V 64 bit softcore in the non-HPS  Agilex fabric  FPGAs (which are at a lower cost than the HPS inclusive devices) .
    regards.
    • AvinashTh_Altera's avatar
      AvinashTh_Altera
      Hi Glen,
      Thanks for the details. I sent you email about tentative timeline to release 64-bit Nios V core.
      Avinash
  • Hi @glenenglish,
    Greetings. I am writing to follow up on the previous clarification and to check whether you have had an opportunity to review it.
    I look forward to hearing from you at your convenience.
    Best Wishes
    BB
    glenenglish
    Hi BB. We have been in contact with Avinash directly and are working on the requirement with Avinash and the Altera FAE.  The Altera timeframe will not meet our requirement, so we will likely use a open source VEXRISCII core. The difficulty will be a lack of tool integration which will be a pain.  regards.
    glenenglish
    If Altera have not decided on a RISCV 64 bit design to use, and need some guidance , I suggest  VexiiRiscv.
    If we go A5 for a design, this is what we will use in absence of an ALtera  solution :
    home :   https://github.com/SpinalHDL/VexiiRiscv
    docs : https://spinalhdl.github.io/VexiiRiscv-RTD/master/index.html
    It is excellent, Efinix provide it in full options , all tool integrated. It has all the kit everyone needs (except the throughput and clock of a hard fabric core) .   example :
    https://www.efinixinc.com/products-riscv.html#pills-riscv64
