15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
15 years agoMichel,
if you disconnect the SDRAM from instruction master Nios processor cannot execute code from SDRAM. What's the size of your SDRAM? --- Quote Start --- "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function across 28 bit boundary is not supported by GCC and will result in linker errors" --- Quote End --- This warning means if you want use the SDRAM as program memory, the address span should be less then 28 bits. Jens
