15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
15 years ago --- Quote Start --- why did you ask me to refer to the system builder? to look at the auto-generated .sdc file ? or look for something else? --- Quote End --- It could be that the systembuilder tool generates a Quartus project file and a SOPC which you can use as a starting point for your design. Did you change the memory allocation in your code? You still have warnigs about address range? Jens
