15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
15 years ago --- Quote Start --- It could be that the systembuilder tool generates a Quartus project file and a SOPC which you can use as a starting point for your design. Did you change the memory allocation in your code? You still have warnigs about address range? Jens --- Quote End --- I used the files generated from system builder from the very beginning. I was going to try the code you gave me, but then i realised, there is no SDRAM_BASE address given to the compiler? so how do i know the software initialize memory in the SDRAM and not in the processor cache, SRAM, RAM, or somewhere else? regards, Michael.
