15 years agoSDRAM problem in SOPC builder
Hi, I get this warning message in SOPC builder saying: "Warning: cpu: The address range of the slaves connected to the NIOS 2 instruction master exceeds 28 bits. Attempts to call function acr...
15 years ago --- Quote Start --- Did you typed in a correct memory profile and timing parameters for the SDRAM in SOPC builder? You could refer the DE2-115 System Builder which is able to generate a Quartus project. --- Quote End --- I copied the timing characteristics settings for SDRAM from terasic's example file(audio). so i think that should be fine. why did you ask me to refer to the system builder? to look at the auto-generated .sdc file ? or look for something else? Michael
