timing_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team,
I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setting) and uses afi_clock(200 Mhz) to connect the clock of other interfaces.
pll_clock of ddr interface is 50 Mhz. connected from the osciallator in the board.
Nios processor also connected with afi clock only (200 Mhz)
For this design , i am getting pll_afi_clock setup time violation.
i have attached the timing report.
PLease give solution for this.
- TingJiangT_Intel
Contributor
Hi there, I can't open timing analyzer with the project you provide, please make sure the timing path can be showed in timing analyzer after you archive the project.
Thanks a lot.
- SERMASWATHIKA
Contributor
Hi ,
I have added the compiled project archive here. i have archived the project in 22.1 . Please compile the project after restoration. then you can open the timing analyser. i have checked in my pc..
- TingJiangT_Intel
Contributor
Hi there, you are using 22,1 std right? I can't start the compilation with your project. It always exit unexpeactly.
- TingJiangT_Intel
Contributor
Here is the error.
BTW I notice that your qsf shows that you used 21.1 pro. May I know the exact edition you are using to open the project.
- SERMASWATHIKA
Contributor
I am using quartus 22.1 version only. And this is the qsf file which i am seeing in my archive folder. I am not sure how this is changing in your tool
- TingJiangT_Intel
Contributor
Hi there, I download your project again. now the qsf of the restored project is the same with what you showed. However I still can't start the compilation process with the same issue.
Can the archived project start compilation process from your side?
- SERMASWATHIKA
Contributor
yes, i have compiled the restored archive project , after that only i have shared to you
- TingJiangT_Intel
Contributor
BTW, you can select the following option when archive the compiled project. With these files we can directly open the timing analyzer, and please check if it can show the paths in timing analyzer after archived.
- SERMASWATHIKA
Contributor
Now i have created the project archive with the options which you have mentioned in the previous message. with version incompatible database file, qar size is exceeded the maximum limit. So i have added qar which has report files alone.
- TingJiangT_Intel
Contributor
It's weird, I failed to restore your project with 22.1 standard edition:
- TingJiangT_Intel
Contributor
Since I can't open your project, please help check following questions:
1, Please check if the launch clock and latch of the violation path are the same clock.
2, Please check the ignored constraint report to make sure all constraints are available.
- SERMASWATHIKA
Contributor
I have checked the launch and latch clock, both are same.
i didnt get the 2nd point you mentioned regarding ignored constraint path.
- TingJiangT_Intel
Contributor
For the 2nd point, there is a report in timing analyzer which shows if there any constraints are ignored.
Check this to make sure if all your constraints are valid.
- TingJiangT_Intel
Contributor
The option is in the task window as following:
- SERMASWATHIKA
Contributor
no constraints were ignored
- TingJiangT_Intel
Contributor
I see. All the violation path are related to which IP? What about the logic level of these violation paths.
- SERMASWATHIKA
Contributor
all violations are from ddr3 ip files. all are related to pll_afi_clock signal
- TingJiangT_Intel
Contributor
In addition, is there any warning message in the timing analyzer?
- SERMASWATHIKA
Contributor
No,There is no warnings in timing analyser
