SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoHi there, I download your project again. now the qsf of the restored project is the same with what you showed. However I still can't start the compilation process with the same issue.
Can the archived project start compilation process from your side?
- SERMASWATHIKA2 years ago
Contributor
yes, i have compiled the restored archive project , after that only i have shared to you
