SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoSince I can't open your project, please help check following questions:
1, Please check if the launch clock and latch of the violation path are the same clock.
2, Please check the ignored constraint report to make sure all constraints are available.
SERMASWATHIKA
Contributor
2 years agoHi,
I have checked the launch and latch clock, both are same.
i didnt get the 2nd point you mentioned regarding ignored constraint path.
