SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoSince I can't open your project, please help check following questions:
1, Please check if the launch clock and latch of the violation path are the same clock.
2, Please check the ignored constraint report to make sure all constraints are available.
- SERMASWATHIKA2 years ago
Contributor
I have checked the launch and latch clock, both are same.
i didnt get the 2nd point you mentioned regarding ignored constraint path.
