SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
TingJiangT_Intel
Contributor
2 years agoBTW, you can select the following option when archive the compiled project. With these files we can directly open the timing analyzer, and please check if it can show the paths in timing analyzer after archived.
- SERMASWATHIKA2 years ago
Contributor
Now i have created the project archive with the options which you have mentioned in the previous message. with version incompatible database file, qar size is exceeded the maximum limit. So i have added qar which has report files alone.
