15 years agoSource of errors in data from SGDMA
Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a video pipeline. It is working but I am getting errors in the data. Whatever the problem is it manifests itself in two ways, the first I believe are errors in writing to the SDRAM which result in vertical lines of one pixel wide on the display, there are always 9 of them in a fairly consistent pattern. The second which I am focusing on are *seemingly* random drops of a few bits from various pixels which results in a 'storm' of dark pixels moving accross the display. Putting SignalTap accross the SGDMA data lines I can see both errors in the data being fed right from the SGDMA. Between the NIOSII program running of it and the refresh commands I cannot be sure of what I see on the SDRAM side. I have calculated my PLL shift and manually moved this up and down from its calculated value (2.08ns) up to 10ns and it makes no difference. Neither does changing the clock of the memory to anything between 40 and 90Mhz. Testing the content of the memory in the program results in incosistent responses, sometimes no errors are reported sometimes one every read. There is no termination on the data lines (OCT or otherwise), but what I dont get is if the SDRAM controller is the source of this how can the NIOSII program run? Does anyone have any idea what could be wrong? (To see what the problem looks like on screen: http://media.diynot.com/103000_102534_26014_87556468_thumb.jpg (http://www.diynot.com/network/sebmaster/albums/6462/26014) http://media.diynot.com/103000_102534_26015_41549493_thumb.jpg (http://www.diynot.com/network/sebmaster/albums/6462/26015)) And for a typical capture of one line in SignalTap: http://media.diynot.com/103000_102534_26013_19009104_thumb.jpg (http://www.diynot.com/network/sebmaster/albums/6462/26013)
