15 years agoSource of errors in data from SGDMA
Hello, Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a vide...
15 years agoIt may depend on the output delay that you stated for the clk pin. Try to put a longer one.
But as long as all your I/O timing requirements are made relative to the clock pin, it shouldn't be a problem. At 70MHz SDR I think that Quartus is able to make you meet the timing requirements without requiring a phase shift. If you get negative slack on the I/O again, you can try and adjust the shift until you don't.
