15 years agoSource of errors in data from SGDMA
Hello, Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a vide...
15 years agoHi Daixiwen,
I created an SDC for the graphics project and this worked well with the exception of a couple of read errors which derailed the program. You must be correct about Quartus meeting constraints at 70Mhz with no phase shift as to resolve this I removed the phase shift and instead extended the minimum input delay to account for my board which probably has a poorer performance than the Altera documentions standard estimate of 0.5ns assumes. Once I added this slight delay the problems were resolved, confirmed with some lengthy memory tests. The display is now working perfectly. Thank you again for all your help. Sebastian
