15 years agoSource of errors in data from SGDMA
Hello, Sorry to be back so quick but I have spent the last two days on this and am at a loss. I have an SGDMA which is reading 16 bit data from an 8bit SDRAM and streaming this to a vide...
15 years agoI don't have a lot of experience debugging those kind of interfaces so I can't be of much help here. The rise time indeed looks long. Are you sure it isn't due to the scope probe?
Did you use a Vref pin for that I/O by any chance? VRef pins have a higher capacity than regular I/O pins, and can cause slower rise/fall times. Did you check also your Timequest assignments? Do you meet all timing requirements?
