Interpolation with CIC Filter
Hello!
I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 100. What I get at the output of the CIC-Filter is a 4.5 kHz sinus signal !! --> there is something wrong! What is the problem here ?? I tried different types of stages and delays, but I won't get a 13.5 sinus. please help me.. Thanks!15 Replies
it could be useful a post of your schematic.
How many samples has a single period of the high frequency sine signal at the output? - Altera_Forum
i think there is a problem with your CIC hardware, because input samples should be synchronized with c0 clock and output samples should be synchronized with c1 clock. Note this, for every input sample 100 samples must go out.
In your hardware, an input sample (synchronized with c0) is read 100 times by a module clocked with c1. As you are using two clocks, in your CIC hardware a dual-clock FIFO for crossing clock domains must be included. - Altera_Forum
Ok. I was thinking in your way too. Because the differentiators has to be clocked with the lower sample rate and the integrators has to be clocked with the higher rate. But I thought the CIC-Filter would do this "clocking" automatically.
The CIC-Filter generated by the MegaWizard has only one clock-input.....how should I solve the problem??... - Altera_Forum
so, you are driving in the wrong way the avalon-streaming signals. in_valid line must be asserted every 100 cycles of 54 MHz clock.
parrado, while i agree with you conceptually this is not how the Altera generated test bench operates.
tobias, have you taken a look at the CIC generated test bench? also take a look at the output error signal in your project. - Altera_Forum
Aha!
@Parrado: This could be the solution! I will try tomorrow in the lab.....in germany know it's 10:20 pm. Thank You parrado! I will let you know if it works.... @thepancake: I will have look at the generated testbench file and the error output too. I will let you know tomorrow. Thanks.. - Altera_Forum
Hello!
I tried to connect the "valid in" with the lower clock. When I set the rate to 5 it works fine. But with a higher rate like 10 or 100 I get a 4.5 kHz-Sinus....it's weird. But I think it is the right way to "clock" the valid in, because in the "functional description" of the CIC-Filter you can see that the "valid in" is clocked too. - Altera_Forum
I am not fans of CIC IP cores but judging by your last work there is possibilty of error. You are supposed to drive the input data in once every 100 clks of output clk. By connecting slow clk to valid in you will violate that when clk is high since many fast clks will be enabled.
OK. So I should set "valid in" set to "VCC" ? How about "clken", "reset_n" and "out_ready" ..... they should be connected to "VCC" too ?
