17 years agoInterpolation with CIC Filter
Hello! I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 10...
17 years agoOk. I was thinking in your way too. Because the differentiators has to be clocked with the lower sample rate and the integrators has to be clocked with the higher rate. But I thought the CIC-Filter would do this "clocking" automatically.
The CIC-Filter generated by the MegaWizard has only one clock-input.....how should I solve the problem??...
