pradeep_12's avatar
pradeep_12
1 month ago
R-TILE PIPE DIRECT MODE SIMULATION PHY STATUS ISSUE IN RESET RELEASE SEQUENCE
HI,
     I am currently working on r-tile pipe direct mode simulation in questasim.  So, initially i have generated r-tile ip with configuration of pipe direct mode, 16x1. I have generated hdls using generate hdl option(enabling verilog,questasim). I have written pipe control fsm to provide control inputs to r-tile ip.
     Ref_clock1,ref_clock2 frequency is 100mhz. Reconfig_clock frequency is 100mhz.  pipe_direct_pld_tx_clk_out_o from ip is 500mhz(validated in sim)
     So, i start with providing ninit_done using reset release ip. once nint_done goes low, i am providing pin_perst_n to high. then pin_perst_n_o goes high. After sometime, pipe_direct_pld_tx_clk_out_o becomes active.  So, i am waiting for ln0_pipe_direct_tx_transfer_en_o to goes high. once this signal goes high, i will release ln0_pipe_direct_pld_pcs_rst_n_i to high. I am checking the phy signal to toggle. but from beginning itself it stays low, it never toggles.
Along with this standard procedure, i tried 2 more possibilities
  1. i tried,  After i released the  ln0_pipe_direct_pld_pcs_rst_n_i to high. I provided the ln0_pipe_direct_txdetectrx_i to high. No response from phy_status.
  2. After i released the  ln0_pipe_direct_pld_pcs_rst_n_i to high. I provided the ln0_pipe_direct_txdetectrx_i , rx_standby to high. still No response from phy_status
I am attaching some screenshots of waveforms. Kinly look into it and help me out. I am really stuck at midway..
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
  • Wincent_Altera's avatar
    Wincent_Altera
    Hi pradeep_12 ,
    The guide shows txdetectrx_i being asserted while the lane is in P1 and the transmitter is electrically idle; it must not simply be held at an arbitrary level after PCS reset. Your waveform appears to leave the lane in P1 and does not show the complete detect-command/deassertion sequence.
    Main issues visible in your waveform
    • powerdown_i appears to remain at 2'b10/P1. You must transition it to P0 after receiver detection.
    • txelecidle_i is not shown. Drive it to 4'hF during P1 receiver detection.
    • Do not assert rxstandby_i during bring-up; that requests RX standby and prevents normal receiver activity. The PHY reports standby through rxstandbystatus_o.
    • txdetectrx_i should be treated as a receiver-detect command and then returned inactive after the phystatus/rxstatus response.
    • Use a sticky debug latch for phystatus, because a one-cycle pulse can easily be missed in a wide Questasim waveform view
    • After the receiver-detect pulse, you will only see cdrlockstatus_o, cdrlock2data_o, RX clock, and reset_status_n_o become active if the simulation includes a valid serial link partner or loopback data.
    Wincent_Altera
