17 years agoInterpolation with CIC Filter
Hello! I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 10...
17 years agoThe samples at the output are ok. It has to be 400 samples right?? I proof that with an analog oscillator.
Maybe you have a look at the image... Thanks for your help!
