17 years agoInterpolation with CIC Filter
Hello! I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 10...
17 years agoOK. So I should set "valid in" set to "VCC" ? How about "clken", "reset_n" and "out_ready" ..... they should be connected to "VCC" too ?
