17 years agoInterpolation with CIC Filter
Hello! I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 10...
17 years agoAha!
@Parrado: This could be the solution! I will try tomorrow in the lab.....in germany know it's 10:20 pm. Thank You parrado! I will let you know if it works.... @thepancake: I will have look at the generated testbench file and the error output too. I will let you know tomorrow. Thanks..
