18 years ago
Speed grades and internal timings
Not so much a problem that I´m having just more something I would like to understand better.
I am currently using a Stratix II GX I-Grade -4 FPGA for a project. I am using Modelsim to carry out timing simulations on my design and am wondering how the .vho file quartus produces specifies the timing delays in the FPGA.
For example if I have a combinational block of logic in the design, does the .vho file always specify, the slowest possible time it could take for a signal to propagate through for a given speed grade?
For example in my -4 (mid speed grade device), would the results of the timing simulation specify a delay on an FPGA which is almost a -5 i.e. a slow -4, or a typical -4 which is centered on the -4 distribution? Or is there a setting somewhere to specify this in Quartus?
Likewise if a device is almost a -3, lets say there is one parameter that downbins it to a -4, would quartus produce the slowest possible timings in the .vho file?
Also just one further question:
Does the -3, -4 or -5 have any real meaning or is it just an arbitrary number assigned to specify the different speed grades. I read somewhere that for example -3 would mean a 3ns delay from point x to point y, but I´m not sure, perhaps it has a meaning to the design engineers regarding internals timings, but to the average user it´s just a number not required to be understood. Could somebody please clarify this.
Thanks you very much for your time
Ardni
