14 years agoSimple Verilog Question--Impossible?
I have a verilog file Intensifier.v. In it is a module with the following port list:
module Intensifier ( clk, _reset, intensifierInput, intensifierOutput ); Now I have a top level file named Main.v. In it I want to instantiate an array of instances of Intensifier. If I code: Intensifier [1023:0]intensifiers; I get the error: "Intensifier is not a type" I am not surprised I get an error, as I have not instantiated Intensifier using a port list. So, in Main.v I code: Intensifier intensifier( .clk(clk), ._reset(_reset), .intensifierInput(mainTestIn), .intensifierOutput(mainTestOut) ); This does not give an error, but it is only a single instance of Intensifier, not an array of Intensifiers. Also, I have assigned mainTestIn and mainTestOut to intensifierInput and intensifierOutput, and if and when I can create an array of intensifiers, I will want each Intensifier in the array to have different inputs and outputs. To be able to use different inputs and outputs, in Main.v I instantiate an instance of Intensifier using a port list but without assigning some inputs and outputs: Intensifier intensifier( .clk(clk), ._reset(_reset), .intensifierInput(), .intensifierOutput() ); This does compile without errors, but I'm not sure how I'll code .intensifierInput and .intensifierOutput later, and I still don't have an array of Intensifiers. To get an array, if, in Main.v, I now try: intensifier [1023:0]arrayOfIntensifiers( .clk(clk), ._reset(_reset), .intensifierInput(), .intensifierOutput() ); Or if now, in Main.v, I try: intensifier [1023:0]ArrayOfIntensifiers; I get the same sorts of errors. Is it possible to instantiate an array of Intensifiers in a similar manner as instantiating an array of reg: reg [1023:0] myregs;8 Replies
DEAR,
Thanks man! I tried your code and it's ok. But i don't know why when i didn't use "signed" to declare signals, it also is ok,however in >+500 and 0-500. Anyway, thanks for your care! Best regards! - Altera_Forum
--- Quote Start --- module check(clk,in,out); input clk; input signed [15:0] in; output [15:0] out; reg signed [15:0] out; always @ (posedge clk) //negedge if (in >= 500) out <= 500; else if (in <= -500) out <= -500; else out <= in; endmodule --- Quote End --- Hopefully code will work now. ( too simple,isn't it? ) Problem :confused: : Operation was being performed as an unsigned one which is not your requirement, it was performing 2's complement and then was comparing. Solution :cool: : Declared signals as " signed" and make value as signed "500 or 16'sd500" ( instead of 16'd500 ) right for comparison. Note : Never give keyword name for declaring identifiers. :) - Altera_Forum
How to implement this condition in verilog??
If input>500------> output= 500 If input<-500-----> output=-500 else --------------> output=input This is my code for this: module check( clk,input,output);input clk;
input [15:0] input;
output [15:0] output;
reg [15:0] output;
always@(posedge clk) //negedge
if (input >= 16'h01f4)
output <= 16'h01f4;
else if (input <=16'hfe0c)
output <= 16'hfe0c;
else
output <= input;
endmodule I don't known why i get wrong result!!! Need for helping!!
--- Quote Start --- I really appreciate people helping each other out. So many folks seem to use the Internet for the purpose of putting others down. --- Quote End --- Simple Concept : If we know something,we say otherwise we subscribe that thread. ;) Pleased to help you. - Altera_Forum
Hi Matthew,
--- Quote Start --- Thank you Dave and Supal. --- Quote End --- You're welcome. --- Quote Start --- I really appreciate people helping each other out. So many folks seem to use the Internet for the purpose of putting others down. --- Quote End --- This forum has managed to stay quite civil :) Cheers, Dave - Altera_Forum
Thank you Dave and Supal. You were both on the right track. Supal, your solution was almost perfect, but you forgot a block name. I added this in my final code, shown below, as "INSTANTIATE_INTENSIFIERS".
I really appreciate people helping each other out. So many folks seem to use the Internet for the purpose of putting others down. Matthew module Test1 ( //inputs clk, _reset, testIn, //outputs testOut ); input clk; input _reset; input [1023:0]testIn; output [1023:0]testOut; wire [1023:0]testOutWire; assign testOut = testOutWire; genvar i; generate for ( i=0; i<1024; i=i+1 ) begin:INSTANTIATE_INTENSIFIERS Intensifier intensifier ( .clk ( clk ), ._reset ( _reset ), .intensifierInput ( testIn ),.intensifieroutput ( testoutwire ) ); end endgenerate endmodule
--- Quote Start --- wire [1023:0] mainTestIn; //wire or reg wire [1023:0] mainTestOut; //wire or reg genvar i; generate for ( i=0; i<1023; i=i+1 ) begin Intensifier inst_i ( .clk ( clk ), ._reset ( _reset ), .intensifierInput ( mainTestIn ),.intensifieroutput ( maintestout ) ); end endgenerate --- Quote End --- I think,you want like this.
When I need to do this in VHDL, I use a for-generate statement. See if you can find the appropriate syntax for Verilog (or SystemVerilog).
Here's what it would look like in VHDL:
The syntax should be pretty similar. Do a search for generate in the Altera sopc_builder/ folder. I know I've seen examples in the Altera verilog code. Cheers, Dave-- Some of these would probably be top-level ports ... signal _reset : std_logic; signal clk : std_logic; signal intensifierInput : std_logic_vector(1023 downto 0); signal intensifierOutput : std_logic_vector(1023 downto 0); ... g1: for i in 0 to 1023 generate u1: intensifier port map ( clk => clk, _reset => _reset, intensifierInput => intensifierInput(i), intensifierOutput => intensifierOutput(i) ); end generate;
