14 years agoSimple Verilog Question--Impossible?
I have a verilog file Intensifier.v. In it is a module with the following port list: module Intensifier ( clk, _reset, intensifierInput, intensifierOutpu...
14 years agoWhen I need to do this in VHDL, I use a for-generate statement. See if you can find the appropriate syntax for Verilog (or SystemVerilog).
Here's what it would look like in VHDL:
-- Some of these would probably be top-level ports ...
signal _reset : std_logic;
signal clk : std_logic;
signal intensifierInput : std_logic_vector(1023 downto 0);
signal intensifierOutput : std_logic_vector(1023 downto 0);
g1: for i in 0 to 1023 generate
u1: intensifier
port map (
clk => clk,
_reset => _reset,
intensifierInput => intensifierInput(i),
intensifierOutput => intensifierOutput(i)
end generate;
The syntax should be pretty similar. Do a search for generate in the Altera sopc_builder/ folder. I know I've seen examples in the Altera verilog code. Cheers, Dave
