Issue with configuring EPCQ64A & Cyclone
I am trying to configure EPCQ64A through Altera Cyclone V(GTFD7D5F).It shows successfully programed the device when I program through JTAG USB Blaster II or USB Blaster, but If I reboot the unit,Config done is OFF (Not successfully configured)
Other issue is, after successful programming, if I try to verify through Quartus, it fails.
Info (209021): Performing CRC verification on device(s)
Error (209027): Verification failed for device number 1
I have tried different Quartus programmer versions (17.1,18.0 18,1,20,1) ,but no success.(.jic file generated using Quartus 18.0)
I have attached the log here.Please help to understand, what could be the issue.
Info (209018): Device 1 silicon ID is 0x17
Info (209044): Erasing ASP configuration device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Mar 08 12:30:46 2024
Info (209060): Started Programmer operation at Fri Mar 08 12:30:53 2024
Info (209023): Programming device(s)
Info (209061): Ended Programmer operation at Fri Mar 08 12:31:51 2024
Info (209060): Started Programmer operation at Fri Mar 08 12:33:27 2024
Error (209012): Operation failed
- FvM
Is it approved development board or custom design? In the latter case you should consider signal quality problems related to design.
To troubleshoot the apparent programming error, you might read out flash data with programmer and check the differences.
- Chrisnu
Hi FvM,
It's a Custom design based on Cyclone V & EPCQ64/EPCQ64 Serial interface flash. This is not a new design and being in production from 5/6 years. I am still checking, but so far, no apparent Signal quality issues are observed.
I ran the examine function after programming and it's susscesful.
Info (209038): Examining devices
Info (209061): Ended Programmer operation at Tue Mar 12 16:06:48 2024
- NurAiman_M_Intel
You said that this has been in production for 5/6 years
- So does this mean that it is suddenly failed?
-Did you make any recent hardware/software changes?
-When did the issue start?
-What is the Quartus version you are using?
-Please try to run the JTAG chain debugger and provide us the screenshot.
-Also try to disable "Unprotect EPCS/EPCQ devices for the erase/program operation" option for Quartus Programmer. Then program again. Does it work?
Aiman
- NurAiman_M_Intel
Any update for this case?
Aiman
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- Arpitmishra
Hello sir , i am also facing same kind of problem. when i am debugging my code , it working fine and i can access the EPCQ64A but when i run the code in standalone mode it, code works but cannot access the memory or write inside epcq64a.
i have quartus prime standard edition 23.1 with license of both NiosII and NiosV. I am using 10CL055YU484I7G and niosv/g as my processor .This whole projects works fine with NiosII processor. but now i want to migrate to NiosV. Kindly help me out.
- Farabi_Altera
Please dont use old thread. This thread is 2024. Please raise new Forum case.
Altera will provide support.
regards,
Farabi
