14 years agoSimple Verilog Question--Impossible?
I have a verilog file Intensifier.v. In it is a module with the following port list: module Intensifier ( clk, _reset, intensifierInput, intensifierOutpu...
14 years agoThank you Dave and Supal. You were both on the right track. Supal, your solution was almost perfect, but you forgot a block name. I added this in my final code, shown below, as "INSTANTIATE_INTENSIFIERS".
I really appreciate people helping each other out. So many folks seem to use the Internet for the purpose of putting others down. Matthew module Test1 ( //inputs clk, _reset, testIn, //outputs testOut ); input clk; input _reset; input [1023:0]testIn; output [1023:0]testOut; wire [1023:0]testOutWire; assign testOut = testOutWire; genvar i; generate for ( i=0; i<1024; i=i+1 ) begin:INSTANTIATE_INTENSIFIERS Intensifier intensifier ( .clk ( clk ), ._reset ( _reset ), .intensifierInput ( testIn ),.intensifieroutput ( testoutwire ) ); end endgenerate endmodule
