14 years agoSimple Verilog Question--Impossible?
I have a verilog file Intensifier.v. In it is a module with the following port list: module Intensifier ( clk, _reset, intensifierInput, intensifierOutpu...
14 years ago --- Quote Start --- module check(clk,in,out); input clk; input signed [15:0] in; output [15:0] out; reg signed [15:0] out; always @ (posedge clk) //negedge if (in >= 500) out <= 500; else if (in <= -500) out <= -500; else out <= in; endmodule --- Quote End --- Hopefully code will work now. ( too simple,isn't it? ) Problem :confused: : Operation was being performed as an unsigned one which is not your requirement, it was performing 2's complement and then was comparing. Solution :cool: : Declared signals as " signed" and make value as signed "500 or 16'sd500" ( instead of 16'd500 ) right for comparison. Note : Never give keyword name for declaring identifiers. :)
