Mikhail_a's avatar
Mikhail_a
2 years ago
RVALID is high after reset on Agilex 7 M-series F2H bridge
Hello
I work with Agilex 7 M-series device and I see a strange behavior of F2H bridge. I see that after deasserting f2h rst_n RVALID and BVALID signal go high, also I see some data coming from RDATA bus:
I see it even when f2h bridge is not connected to anything. Here are settings for HPS:
I use Quartus 23.4.
So probably you know what can be wrong here?
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Any update on this case?
    Are you able to get the signalTap waveform on your board?
    Jingyang, Teh
    tehjingy_Altera
    Hi Mikhail
    Could you get another screen shot with the following signals so that we could analyze it better?
    ARADDR
    ARVALID
    ARREADY
    RDATA
    RLAST
    RVALID
    RREADY
    Jingyang, Teh
  • Mikhail_a's avatar
    Mikhail_a
    Hi
    I'm sorry, but it seems you may have missed the fact that in all those data beats RLAST is 1 and ARLEN is 7Fh which means I should get 128 data beats for each of 16 read requests. But what you see on the picture is everything I have here, there are no more data beats.
    Best
    Mikhail
    tehjingy_Altera
    Hi
    In the last screenshot you shared the ARLEN is 7H. Which correspond to 8 beats of data in the transaction.
    Could you share any SS shot of the DATA and ARLEN where the ARLEN is 0 and there are data beats?
    Jingyang, Teh
      Mikhail_a
      Hi
      Unfortunately as you can see there is an AXI4 spec violation as ARLEN is not zero and the number of returned data beats corresponds to ARLEN == 0
      So I cant say the bridge works correctly
    tehjingy_Altera
    Hi Artavazd
    I am Jingyang and I will be taking this case over from Eber.
    Please give me sometime to be up to speed on this case and will reply to you as soon as possible.
    Jingyang, Teh
  • Artavazd's avatar
    Artavazd
    Hi
    This piece of log
    FPGA not ready. Bridge reset aborted!
    ...........FPGA reconfiguration OK!
    goes from U-Boot as it tries to disable bridges before programming FPGA, after that it enables them and as enabling bridges was successful there are no more messages about it.
    As I see bridges are configured alright, at least I'm able to use HPS to FPGA bridge with no issues.
    To be honest I see no connection between HBM and FPGA2HPS bridge, they are completely separated IP and I don't think HBM can somehow help me here.
    I haven't seen any AXI settings for FPGA2HPS bridge such as burst length, I thought it is just supposed to support lengths more than one.
    Mikhail_a
    Some update
    I've upgraded Quartus to 24.1, upgraded u-boot fsbl to 2023.10
    and now I see that RVALID signal is low after reset, but It looks like ARLEN signal is not connected to where it should be. So on any read request the bridge returns only one transfer of data with RLAST high irrespective to any ARLEN I send. It looks like ARLEN is always zero right now.
  • Hi,
    Are you using this board?:
    https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agm039.html
    May I know how you boot up the board, using SD card etc?
    Can you explain briefly how you perform the reset, is it thourgh the signal tap?
    Also, if you do a power cycle of the board does the signal also behave the same?
    If you are using the above aforementioned board, we have the GSRD for it:
    https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDDEVAGM039F
      Mikhail_a
      Hi!
      You are right I use the exact same board.
      I used this GSRD from the rocketboards as a reference. But as I found out its u-boot doesn't enable FPGA-HPS bridges, so I have to build u-boot as described here https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7 while using the same kernel and fsbl binary as in mentioned GSRD.
      I have a custom module that holds asserted reset for couple of minutes so I have time to enable signaltap and observe its deasserting. But even without this module I see that after ninit_done is asserted i have RVALID high. I see this issue every time I boot the board.
      • EBERLAZARE_I_Intel's avatar
        EBERLAZARE_I_Intel
        Just want to check if you are also using the latest versions of the source code releases, U-boot = socfpga_v2023.10 etc..?
        Okay, so using the GHRD from Rocketboards, the FPGA configuration is done right before "starting the kernel", including enabling the FPGA bridges:
        Is it possible that you check again the signals behavior after booting to Linux as root in the signal tap? That would confirm that the bridge and FPGA enable and configured and the signal should behave as it should.
        If you still see otherwise, let us know.
