interface stratixIV with an external ultrafast comparator
Hi everybody :)
we need to interface ultrafast comparator- ADCMP572 - of analog device to a stratix4 device to perform one bit conversion. we expect that the comparator will ouput very short pulses(200 ps). The goal is to sample those pulses with FPGA. The comparator datasheet is attached 1) from a physical point of view, at which FPGA INPUT should we connect the output of the comparator -CML- in order that the short pulses can travel the FPGA with a minimum distortion ? must we connect to stratixIV transceiver only or can we to another inputs ? 2) we need to drive the LATCH differential input with a minimum jitter (<100ps) ? From which output of FPGA should we drive it ? must we connect to stratixIV transceiver only or can we to another inputs ? Waiting for your response.. Shalom30 Replies
Hi everybody!
we have talked with the FAE in our country, and he tell us that for this application we cannot use the GT receiver because we need to transmit with 8/10 in order that in the receiver we can use the clock recovery... is this true ?? The question is : in application that we dont use the transmitter gt, can we sample an asynchronous signal with the GT receiver only ( with a specified data rate) ? Shalom - Altera_Forum
OK JosyB and FvM ! its already a good information.
Thanks for Help, i think we have no choice..We can't use a custom design only go with transceiver megafunction, using your advices to implement it ! - Altera_Forum
I complete agree with josyb's understanding of the GXB hardware capabilities. That's, what the transceiver block is designed for. I don't expect that there are other connection options for the specific blocks than shown in the hardware manual.
The GX/GT pins are connected to the GX/GT blocks and I didn't see a possibility to drive them directly from the a PLL or any other logic for that matter. You could ask your FAE to verify that. However generating the clock via the GX/GT block like I described is not difficult nor that time consuming. I normally make a small project to test such things using the Quartus internal simulator in timing mode (in fact that's what I'm doing now for a StratixII GX project ...)
what we can tell for the application: we have a periodic random signal that we want to sample.
this random periodic signal can be a high accuracy radar echo that we want to sample. We expect comparator output pulses of 100-200ps width, and larger. Given that the signal is periodic, we can sample at each period at a different phase, by driving the Latch input at different phase! A StratixIV PLL can generate a clock with a 78ps phase delay (dynamically reconfigurable), so we can sample at each period, with this clock , at phase delays of 78ps, so having a sampling rate of 78ps. So what is most important for us now, is to achieve a relatively low jitter, and not necessarily a high speed... Later, we will also want to sample this periodic signal also with the aid of GT receiver megafunction.. but NOW we want to check what are the limit whithout using GT magafunction. This is why we are asking, is there any possibilitys of using GT I/O PIN without using GT megafunction , just to use the high frequency capability of those PIN, if there ? in order that the signal can enter the FPGA with a minimum distortion-from comparator output; or output the FPGA with a minimum jitter, to drive the Latch input. - Altera_Forum
I don't think you can use the GT IO pin as the output of any PLL, that's why I suggested using the TX-part of a GT block and generate a 5 GHz clock with tying a fixed pattern of 0101010... to the transmitter data input.
Using a normal PLL's output has way too much jitter. What is the actual speed your are aiming at? I just went for the idea that you'd use a StratixIV for it's speed. Can you tell us more about the application ? (just male curiousness ...) - Altera_Forum
What is important for us now is not the high frequency we can achieve for the Latch input, but the jitter of its driver, is the important parametter for a better accuracy of the sampling,so..
..I mean, feed the Latch input from a PLL output only, by using the GT I/O PIN on the StratixIV but without using GT magafunction. what about this? what will be the jitter of this output ? - Altera_Forum
Shalom,
Referring back to the SIV manual it could be down to 27.6 ps The latch enable for the comparator is effectively the output of a GT transmitter block running at 10 (or 11.3) GHz and generating a 5 GHz clock with about 32 ps jitter, but it then relies on using the nearby RefClk inputs. You could use an external clock synthesizer (e.g. ADF4350) to generate a very low jitter input clock with programmable phase. - Altera_Forum
Probably Higher...
But there is a dynamic(real time) reconfiguration into the PLL-with a 78ps resolution. we can eventually use this option to "achieve the phased sampling". Mean feed the latch input from a pll output only by using the I/O GT ? the jitter will be always inferior to 100ps ?? - Altera_Forum
Looking at the DC and Switching Characteristics page 1-38 and 1-39 Altera specifies/mentions a 0.32 UI total jitter for the XLAUI/CAUI case and also .032 UI for the SFI-S transmitter at 11.3 Gbps. This comes down to 27.6 ps.
Both specs have high RefClk frequencies (644.53 and 706.25) driven at the dedicated reference clock inputs. Shalom, that's about what I had in mind. However just using the physical IO is not enough, you'll have to pass via the GT blocks, but you can use the MegaWizard to generate the TX-part to generate the Latch signal and the RX-part to sample the incoming signal. To achieve the phased sampling you will probably have to use an external oscillator with a variable phase. I don't see any references in the Stratix IV doc about this. Remember the GX/GT blocks are made for communication and as such only need to generate a 90 degree (or centered) internal clock to sample the incoming data stream. Using an internal PLL to feed the GT block is a possibility but the jitter may be higher?
