IS25LP064A interface with Cyclone V HPS
Hi all,
has anyone tried accessing serial NOR flash IS25LP064A using QSPI driver within hwlib ? I have successfully performed initialisation, setup device configuration. The problem is that a read attempt (Normal Read and Fast Read) after executing erase sequence returns all zeros instead of all ones. has anyone else faced similar issue ?
Best Regards
Naresh
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
