16 years agointerface stratixIV with an external ultrafast comparator
Hi everybody :) we need to interface ultrafast comparator- ADCMP572 - of analog device to a stratix4 device to perform one bit conversion. we expect that the comparator will ouput very short...
16 years agoI don't think you can use the GT IO pin as the output of any PLL, that's why I suggested using the TX-part of a GT block and generate a 5 GHz clock with tying a fixed pattern of 0101010... to the transmitter data input.
Using a normal PLL's output has way too much jitter. What is the actual speed your are aiming at? I just went for the idea that you'd use a StratixIV for it's speed. Can you tell us more about the application ? (just male curiousness ...)
