16 years agointerface stratixIV with an external ultrafast comparator
Hi everybody :) we need to interface ultrafast comparator- ADCMP572 - of analog device to a stratix4 device to perform one bit conversion. we expect that the comparator will ouput very short...
16 years agoShalom,
Referring back to the SIV manual it could be down to 27.6 ps The latch enable for the comparator is effectively the output of a GT transmitter block running at 10 (or 11.3) GHz and generating a 5 GHz clock with about 32 ps jitter, but it then relies on using the nearby RefClk inputs. You could use an external clock synthesizer (e.g. ADF4350) to generate a very low jitter input clock with programmable phase.
