11 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 100 MHz to the rest of the design.
However I am having problems, I made a SDC and I am having timining problems, says my fmax of the ALT PLL output is 91.73 MHz. I used to use altpll and everything used to work, but altppl is not compatible to Cyclone V so I have to use the Altera PLL. What can I do? I've played a little bit with Quartus II configurations and the sdc file but it was useless...
