12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years agoCan it be that your misunderstanding the timing report? I guess the problem is that your design can't run at 100 MHz, the PLL shouldn't have problems to generate 100 Mhz (or 200 MHz).
