12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years agoIf fmax is only 91.73 MHz instead of 100 MHz the following things should be investigated:
- .sdc proper timing constraints must be added to this clock pin. - if PLL has a problem, it is always displayed be the Qsys GUI if configuring the Altera PLL IP ( clock not compensated .... e.g 100 MHz vs. 99.9 MHz) I think your problem is the first, bad or missing timing constraints. I suggest to look the following good documentation: http://www.alterawiki.com/wiki/timequest_user_guide
