12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years ago --- Quote Start --- It could be but when I take out the DMA of the Bridge I have no timing problems, All I have in this bridge (FPGA2SDRAM) is a TSE MAC and a DMA and that's pretty much my whole design... If the timing report says this FMAX is 91.73 MHz I don't have much to misunderstand, do I? Thanks --- Quote End --- I think you have timing constraint problem. - check .sdc file for the clock signal and add a proper timing constraint It is not a Altera PLL IP problem (you can check it in Qsys GUI, that all clocks compensated. It it has a problem that means 99.9 Mhz instead of 100 MHz). I suggest to examine the following good documentation. http://www.alterawiki.com/wiki/timequest_user_guide
