12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years ago --- Quote Start --- I have tested all bridges (H2F, F2H, H2F_LW). They can work ~ 100 / 133 / 166 MHz clock frequencies. I have no information about the FPGA2SDRAM interfaces. (note. this is a interface, not a bridge). --- Quote End --- Thanks for your answer, which FPGA have you used? Did you connect more than one component to the F2H/H2F/H2F_LW bridge? I have the problem when I connect a DMA and the TSE Mac to the F2S bridge.
