10CL080YF780I7G BSDL FILE
We are currently using your 10CL080YF780I7G in our design.
in the BSDL file, pin F4 is defined as a linkage bit, which prevents us from toggling it through boundary scan.
However, in our design, we are using pin F4 as an output. The design compiles successfully in Quartus without any errors or warnings indicating that this pin should not be used in such a manner.
Could you please clarify why pin F4 is defined as a link bit in the BSDL file?
Is there a recommended workaround or update we should apply to ensure proper JTAG functionality?
.pin file:
BSDL file:
Please note that we have encountered the same problem with the following devices:: 10CL040YF484I7G and 10CL016YF484I7G pin E2 is defined as out bit, while it is IO.
We appreciate your guidance and look forward to your advice.
- Yifat
- FakhrulA_altera
Hi Yifat,
I see that this question is currently being handled through an APS support case. To avoid duplicate discussions and keep all communications in one place, I will close this thread.
Should you have any other questions in the future, please feel free to create a new thread.
Fakhrul
- FakhrulA_altera
Thank you for reporting this issue and sharing the details.
We understand that Quartus allows pin F4 to be used as an output, but the BSDL file defines it as linkage. Because of this, the pin cannot be controlled through boundary scan.
We will check with our internal team to confirm whether this is a device limitation or an issue with the BSDL file. We will also ask them to review pin E2 for 10CL040YF484I7G and 10CL016YF484I7G.
For now, please do not change the BSDL file manually. Could you please share the BSDL filename or download date, and the Quartus Prime version you are using?Regards,
Fakhrul
