12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years ago --- Quote Start --- I know it's not a PLL per se problem, I think I really made the wrong question. I would like to know the the FPGA2SDRAM / FPGA2HPS LW bridges can run at 100MHz; I get the top falling path from the SOC System LW Bridge to the HPS System with a slack of -0.4 --- Quote End --- I have tested all bridges (H2F, F2H, H2F_LW). They can work ~ 100 / 133 / 166 MHz clock frequencies. I have no information about the FPGA2SDRAM interfaces. (note. this is a interface, not a bridge).
