--- Quote Start ---
Hi,I'm sorry! and I forget it .
my <>.qsf is
# Copyright (C) 1991-2009 Altera Corporation
# Your use of Altera Corporation's design tools, logic functions
# and other software and tools, and its AMPP partner logic
# functions, and any output files from any of the foregoing
# (including device programming or simulation files), and any
# associated documentation or information are expressly subject
# to the terms and conditions of the Altera Program License
# Subscription Agreement, Altera MegaCore Function License
# Agreement, or other applicable license agreement, including,
# without limitation, that your use is for the sole purpose of
# programming logic devices manufactured by Altera and sold by
# Altera or its authorized distributors. Please refer to the
# applicable agreement for further details.
# Quartus II
# Version 9.0 Build 132 02/25/2009 SJ Full Version
# Date created = 17:02:23 July 13, 2009
# Notes:
# 1) The default values for assignments are stored in the file:
# zhengxing_assignment_defaults.qdf
# If this file doesn't exist, see file:
# assignment_defaults.qdf
# 2) Altera recommends that you do not modify this file. This
# file is updated automatically by the Quartus II software
# and any changes you make may be lost or overwritten.
set_global_assignment -name FAMILY "Cyclone II"
set_global_assignment -name DEVICE EP2C5T144C8
set_global_assignment -name TOP_LEVEL_ENTITY zhengxing
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 9.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "17:02:23 JULY 13, 2009"
set_global_assignment -name LAST_QUARTUS_VERSION 9.0
set_global_assignment -name USE_GENERATED_PHYSICAL_CONSTRAINTS OFF -section_id eda_blast_fpga
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85
set_global_assignment -name VERILOG_FILE zh.v
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region"
set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region"
set_global_assignment -name MISC_FILE "E:/cheng_xu/zhengxing/zhengxing.dpf"
set_global_assignment -name QIP_FILE pll_0.qip
set_global_assignment -name BDF_FILE zhengxing.bdf
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVTTL"
set_location_assignment PIN_17 -to clk
set_location_assignment PIN_51 -to data_in
set_location_assignment PIN_48 -to data_out
set_location_assignment PIN_75 -to rst
set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED"
set_global_assignment -name RESERVE_ALL_UNUSED_PINS_NO_OUTPUT_GND "AS OUTPUT DRIVING AN UNSPECIFIED SIGNAL"
set_global_assignment -name STRATIX_CONFIGURATION_DEVICE EPCS1
set_global_assignment -name RESERVE_ASDO_AFTER_CONFIGURATION "AS INPUT TRI-STATED"
set_global_assignment -name VECTOR_WAVEFORM_FILE zhengxing.vwf
set_global_assignment -name SETUP_HOLD_DETECTION ON
set_global_assignment -name SETUP_HOLD_DETECTION_INPUT_REGISTERS_BIDIR_PINS_DISABLED ON
set_global_assignment -name SIGNALTAP_FILE stp1.stp
set_global_assignment -name ENABLE_SIGNALTAP OFF
set_global_assignment -name USE_SIGNALTAP_FILE stp1.stp
thank you!
--- Quote End ---
I did not see your verilog file ( in your first post) in the qsf. Are you using the zhengxing.bdf ? Is your reset signal connected ? Polarity ?
Kind regards
Gerd
