17 years agoa strange problem!
module zhengxing(clk_200M, rst, data_in, data_out ); input clk_200M; input rst; input data_in; output data_out; reg data_out; reg [2:0]counter; reg [1:0]state; parameter low...
17 years ago --- Quote Start --- Hi, there could be a lot of reasons why your design is not running on the FPGA. It would help when you at least post your <>.qsf in the forum, because then we can check your settings. Kind regards Gerd --- Quote End --- Hi,I'm sorry! and I forget it . my <>.qsf is # --------------------------------------------------------------------------# # # Copyright (C) 1991-2009 Altera Corporation# Your use of Altera Corporation's design tools, logic functions # and other software and tools, and its AMPP partner logic # functions, and any output files from any of the foregoing # (including device programming or simulation files), and any # associated documentation or information are expressly subject # to the terms and conditions of the Altera Program License # Subscription Agreement, Altera MegaCore Function License # Agreement, or other applicable license agreement, including, # without limitation, that your use is for the sole purpose of # programming logic devices manufactured by Altera and sold by # Altera or its authorized distributors. Please refer to the # applicable agreement for further details.# # --------------------------------------------------------------------------# # # Quartus II# Version 9.0 Build 132 02/25/2009 SJ Full Version# Date created = 17:02:23 July 13, 2009# # --------------------------------------------------------------------------# # # Notes:# # 1) The default values for assignments are stored in the file:# zhengxing_assignment_defaults.qdf# If this file doesn't exist, see file:# assignment_defaults.qdf# # 2) Altera recommends that you do not modify this file. This# file is updated automatically by the Quartus II software# and any changes you make may be lost or overwritten.# # --------------------------------------------------------------------------# set_global_assignment -name FAMILY "Cyclone II" set_global_assignment -name DEVICE EP2C5T144C8 set_global_assignment -name TOP_LEVEL_ENTITY zhengxing set_global_assignment -name ORIGINAL_QUARTUS_VERSION 9.0 set_global_assignment -name PROJECT_CREATION_TIME_DATE "17:02:23 JULY 13, 2009" set_global_assignment -name LAST_QUARTUS_VERSION 9.0 set_global_assignment -name USE_GENERATED_PHYSICAL_CONSTRAINTS OFF -section_id eda_blast_fpga set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0 set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85 set_global_assignment -name VERILOG_FILE zh.v set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region" set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region" set_global_assignment -name MISC_FILE "E:/cheng_xu/zhengxing/zhengxing.dpf" set_global_assignment -name QIP_FILE pll_0.qip set_global_assignment -name BDF_FILE zhengxing.bdf set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "3.3-V LVTTL" set_location_assignment PIN_17 -to clk set_location_assignment PIN_51 -to data_in set_location_assignment PIN_48 -to data_out set_location_assignment PIN_75 -to rst set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED" set_global_assignment -name RESERVE_ALL_UNUSED_PINS_NO_OUTPUT_GND "AS OUTPUT DRIVING AN UNSPECIFIED SIGNAL" set_global_assignment -name STRATIX_CONFIGURATION_DEVICE EPCS1 set_global_assignment -name RESERVE_ASDO_AFTER_CONFIGURATION "AS INPUT TRI-STATED" set_global_assignment -name VECTOR_WAVEFORM_FILE zhengxing.vwf set_global_assignment -name SETUP_HOLD_DETECTION ON set_global_assignment -name SETUP_HOLD_DETECTION_INPUT_REGISTERS_BIDIR_PINS_DISABLED ON set_global_assignment -name SIGNALTAP_FILE stp1.stp set_global_assignment -name ENABLE_SIGNALTAP OFF set_global_assignment -name USE_SIGNALTAP_FILE stp1.stp thank you!
