17 years agoa strange problem!
module zhengxing(clk_200M, rst, data_in, data_out ); input clk_200M; input rst; input data_in; output data_out; reg data_out; reg [2:0]counter; reg [1:0]state; parameter low...
17 years ago --- Quote Start --- Hi, I assume that the code represents the whole design ??? If yes, please post your project in the forum. Kind regards Gerd --- Quote End --- this module is only use to do with square wave,when the square wave with some unstable signal on its edge input into the input pin ,i want to use this module to get a stable square wave .and after getting the square wave from this module ,i think it can make other module work well.but i find it not work; the square wave inputting into the input pin is below 10M;
