17 years agoa strange problem!
module zhengxing(clk_200M, rst, data_in, data_out ); input clk_200M; input rst; input data_in; output data_out; reg data_out; reg [2:0]counter; reg [1:0]state; parameter low...
17 years ago --- Quote Start --- this module is only use to do with square wave,when the square wave with some unstable signal on its edge input into the input pin ,i want to use this module to get a stable square wave .and after getting the square wave from this module ,i think it can make other module work well.but i find it not work; the square wave inputting into the input pin is below 10M; --- Quote End --- Hi, there could be a lot of reasons why your design is not running on the FPGA. It would help when you at least post your <>.qsf in the forum, because then we can check your settings. Kind regards Gerd
