Arun_Prabakatr's avatar
Arun_Prabakatr
9 months ago
Operating system kernel-level FPGA bridge communication
We are using a custom (Agilex 5) platform and need to access the FPGA bridges from the Linux kernel. We are unable to locate the corresponding device tree nodes or modifications required to access these memory-mapped regions. We're aware of the devmem2 package, but we want to access the FPGA from the kernel side without relying on it. Please guide us on how to configure the device tree and use kernel-level commands or interfaces to access the HPS-to-FPGA and Lightweight HPS-to-FPGA bridges.
configuration from Linux.
CONFIG_OF_RESOLVE y
CONFIG_OF_OVERLAY y
CONFIG_OF_CONFIGFS y
CONFIG_FPGA_MGR_STRATIX10_SOC y
CONFIG_FPGA_BRIDGE y
CONFIG_FPGA_REGION y
CONFIG_OF_FPGA_REGION y
CONFIG_OVERLAY_FS y
  • RaduB_Altera's avatar
    RaduB_Altera
    Hi Arun,
    It is not clear from the thread if your issue is solved.
    To summarize, on Stratix 10 and newer devices, you will not see the bridges as individual entries in the device tree. The bridges can be enabled by running the 'bridge enable' command in U-Boot, which is also invoked automatically when using the 'bootm' with FPGA fabric configuration. The bridges are also automatically enabled when a Linux device tree overaly is applied.
    The actul fabric configuration from Linux is similar on all Stratix 10 and newer devices. You can see an example for Agilex 7 here: https://altera-fpga.github.io/rel-25.3.1/embedded-designs/agilex-7/f-series/soc/fabric-config/ug-linux-fabric-config-agx7f-soc/
    Please let me know if you still need help with this issue. I can provide a complete example if you let me know exactly what you need.
    Thank you,
    Radu
    • tehjingy_Altera's avatar
      tehjingy_Altera
      Dear Customer,
      Since no further clarification is needed on this thread, it will be transitioned to community support for further help on doubts in this thread.
      Please login to the Altera Community Forum and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
      Thank you for the questions and as always pleasure having you here.
      Best Wishes
      Altera Tech Support
  • TiensungA_Altera's avatar
    TiensungA_Altera
    hi,
    By right, the devmem2 must be used to read/write to the HPS2FPGA bridge using the mapping below for Agilex5. I can see that your mapping is incorrect.  If you are using the LW HPS2FPGa, it starts at 0x1FC0_0000.
    You do not need to create any nodes in the device tree. The nodes in the device tree are only required if you are writing/using SOFT IP Device drivers in Linux kernel to access the bridge. Without drivers and with user-space interface, you should be able to use devmem2.
    The bridges will be enabled by default if you do a FPGA configuration in Linux. If you perform this in U-boot, you will have to do a bridge enable in uboot before booting the Linux.  The configs that you use above example, CONFIG_FPGA_BRIDGE and _REGION are only required if you are doing FPGA configuration in Linux as they are required by the FPGA manager device driver "stratix10_soc.ko" driver to configure the 2nd stage FPGA core.rbf. In short, the bridges should be enabled if you have configured the FPGA in UBOOT prior to loading Linux.
  • AlanCLTan's avatar
    AlanCLTan
    Hi Arun,
    devmem2 is the most common and easiest way to access a FPGA bridge from Linux kernel, to do it another way, you could try adding a node similar to https://www.kernel.org/doc/Documentation/devicetree/bindings/fpga/altera-hps2fpga-bridge.txt into https://github.com/altera-fpga/linux-socfpga/blob/QPDS25.1_REL_GSRD_PR/arch/arm64/boot/dts/intel/socfpga_agilex5_socdk.dts, but with another values for register range, reset, and clock. You will also need a custom driver to access the node you created.
    • Arun_Prabakatr's avatar
      Arun_Prabakatr
      Hi AlanCLTan​,
      We have followed the procedure as per the document and enabled all the drivers related to the bridge but the fpga_bridge directory is still empty. We have also attached our updated DTS.
        tehjingy_Altera
        Hi
        As we do not hear back from you for sometime, we will transition this thread into community support onwards.
        tehjingy
      Arun_Prabakatr
      Hi AlanCLTan,
      We are aware that we can access the bridges using U-Boot as well as the devmem2 tool in Linux. However, similar to what was done for Arria 10 and Stratix devices (as shown below), we need to validate this functionality on Agilex 5. If you have any ideas or guidance on this, please let us know.
      Arria 10 Ref :
      From source DOC:
      How to configure FPGA from Linux
      https://malt.zendesk.com/hc/en-us/articles/900006256923-How-to-configure-FPGA-from-Linux
      Checking bridge and  enable :
      https://malt.zendesk.com/hc/en-us/articles/900005300186-U-Boot-HPS-FPGA-Bridge-Open-Command-for-SoC-FPGAs
      We are indeed looking to validate the above on the QPDS25.1 Linux version 6.12.11.incase if you any other method from linux OS please let us know
